Adding floors to imported cad file
Hi
I am relatively new to Sketchup and a beginner user. I have converted a pdf from an architectural plan into cad and imported it into Sketchup. I have started grouping and tagging all of the geometry, however there are no floors on the imported cad file. I am really struggling to put floors into the plan. I have tried to draw lines around the internal walls and then group them together, however when I zoom in the lines do not fully follow the internal wall line and Im worried I am going to spend a significant amount of time messing it up!
Any help would be greatly appreciated thank you so much
Katie
Master Copy Ground Floor Home.skp (11.9 MB)
I cleaned up your file manually, using extension would´ve deleted stray edges, yo had the human scale like 2 km away from the rest of the model, that causes some glitches like the ones you saw, I didn´t check every part to find those gaps, but I tried to group the geometry corresponding to a tag and then put the group on the tag of the inside geometry, there were some objects without tag. Now when you do something like this, the best way to do it as a beginner
is to use the cad file just as reference, and model from scratch using the native tools, and grouping the walls, doors, windows and every other object and at the end assign a tag to the groups and components you modeled.
Master Copy Ground Floor Home.skp (6.2 MB)
Thank you so much for all your help, I greatly appreciate it and your advice!
