Base Case.skp (266.8 KB)
Attached is a simple base cabinet. Is it possible to add a face frame and door to this component or do I have to start from scratch?
You can edit the component and add the needed sub-components to it. You’ll need to add the requisite properties to handle those components and, depending on the way you add the face frame components, you might need to edit the functions for the existing case pieces.
Thank You! Am trying now.
One thing to note is that if you already have placed multiple different copies of a DC into your model, the edits you do apply only to the one copy you are editing, and new copies based on that. The nature of the DC system requires that in most cases every DC becomes unique.
