Add More Imagery
I’ve just purchased the pro license and I"m use a macbook pro. I’m trying to follow the Architecture Building from Reference tutorial but the Geo-Locate option has now changed to “Add Location”, which is fine. However the next step is “Add More Imagery” and I can’t find that option anywhere. Can anyone help?
I’ve tried using help - the gives me option to “Geo Locate - Add More Imagery” but if I click on that I get an error message telling me there is a more updated location option.
The UI has changed since the tutorial was created. Also you should update the Add Location extension from the Extension Warehouse.
After you add the first location imagery you’ll be asked if you want to add more or stop adding and go back to SketchUp.
Thanks for help. Appreciate it.
You’re quite welcome.
BTW, please update your forum profile since you have upgraded from Go to Pro.
Done! Cheers
Sorry to be back again but I’ve followed your instructions and it’s worked perfectly but now it’s saying delete the 2d map and keep the image map. In the tutorial it just says to delete it but it always deletes the image map and I can’t work out how to switch between them. Any ideas? Or should i put up a new post in the community?
I’m trying to go through the tutorials step by step to get everything right and not be asking too many simple questions on forum. However, whilst the initial beginner tutorial seemed pretty straightforward, this one doesn’t seem to correlate much to what I’m seeing on the screen! Thanks again for your
Go into the Tags panel and open the Location tag folder. Turn off the tag for the image leaving only the drawn map. Unlock the map and then delete it. Turn the tag back on for the image.
If you note in the video, although Eric says to get the same area for the second import, the size is different. This makes it easier to select and unlock just the one you want without unlocking both.
After you’ve deleted the map take a moment to purge unused stuff from Model Info>Statistics.
Thanks Dave - very helpful.
