Add Location Blue Marker Visibility
Since I started to use Add Location, the files that have been geolocated now have a blue marker at the origin that is visible at all times even through geometry. Is there any way to turn this off?
Turn it off in the View menu.
That was easy. Can’t believe I didn’t see that. Thanks.
It’s a new feature. I had to look for it when it first popped up.
@trent, sorry. I don’t know who else to pester about this. Would it be possible to set the location pin to off in the user’s template? I tried turning it off in the View menu and then creating a new template but it is still being displayed when I open that template. Thanks.
Just so we’re all on the same page, you’re talking about the new lab extension Add Location , not the standard one.
I’m moving the thread to the SketchUp Labs section
Yeah, tried it, also the pin is huge and a bit blurry compared to the rest of the window. might be nice to downscale it a bit.
Capture d’écran 2024-01-05 à 19.38.47
could be 3-4 times smaller with this resolution. or maybe it needs a vector icon
Yeah, the extension. Thanks.
No problem @DaveR , I will pass this onto the appropriate folks.
Trent
