Add glazing/window-by percentage of wall area
Hello,
I use SketchUp to create energy models by building simple geometry using surface and export the geometry into other software using custom plugins for respective software like Sefaira, IESVE, openstudio, etc. I am trying to see if there is a plugin in SketchUp which will add glazing to the external walls as a function of percentage of external wall area?
any pointers will help.
Thank you for your time and assistance.
-Aditya_P
Math :smile:
Quantifier Pro?
You can make a piece of a wall with a window as a dynamic component, with the windoe size determined by a formula relating to a percentage.
You know you can override glazing ratio’s in Sefaira once uploaded in the web application?
It certainly would be nice to have it pushed back into the model.
I think it should be included in the software itself, especially since the introduction of PreDesign:
@corney
Check this site:
http://u001.arch.cf.ac.uk/plugin/
