Accidental overwriting of a file
Hi guys.
I accidentally over wrote a file in my sketch up library with a new file and I was working on the file for the past 6 months. Is there any way to revert to a previous save point? the document has been closed since. I assume since the file has been overwritten there is no way to get the original back but just in case id love to know if there is a procedure that exists. I really loved the one that got deleted.
any help is appreciated.
thanks,
Austin
I still have the original .skb with the correct content but the sketch up file is overwritten. I tried using the restore previous versions button but it says there are none in the queue. please help.
If you have a good .skb file then you’re golden.
First make a copy of the .skb file so you have a backup just in case.
Then rename the .skb file to a new file with a .skp extension.
That’s it.
I just need to rename the extension?? wow, ok thanks a lot!
For the future: you shouldn’t work on a file for 6 month and don’t create a backup from time to time… there are plugins for SketchUp that support the creation of backups…
thanks mate, you saved my life
I regularly make a complete backup of my internal SSD on an external hard drive. This saved my life a few times so far. My drive is 1 TB. I use a 2TB external drive. These can be bought for about 110 $ Can these days. I saw one that is advertised at about 80 $ Can + tax on Amazon. That is not much to be safe.
I use Cobian Backup which creates a backup of my selected directories every night. At any given time there are 4 previous backups saved. The are set up as FIFO so the oldest one gets shoved out when the new one gets written.
