Is it possible to add the domain @iccastelvetro.edu.it to the whitelist for students and teachers to use skechup?
Access goes in a loop.
@CaseyG is the person who can help you with that. I pinged him for you.
You likely have to wait untill the weekend is over..
Thank you. You are truly kind.
Thank you 1000 and have a good evening
Hi @ThebigbugICC. thanks for the post. I can get you added to our database of approved domains easily. I just need to verify that you are not a higher education school. I was 99% sure you are elementary age students but relying on Google Translate is not always accurate so I need you to confirm it in a post. Just let me know yes or no and I’ll either get you added or send you to the right place for higher education licenses.
Hi Grothus,
Sorry, but I use automatic translation, I didn’t understand if I should reply to you via email or on the forum. Anyway, I will reply to both messages.
I confirm: The Istituto Comprensivo di Castelvetro (ICC) is a group of schools that go from nursery school (3-5 years) to elementary school (6-10 years) and lower secondary school (11-13 years).
I thank you for your attention to our difficulties and I wish you a good day (even if it’s 9 pm here).
Roberto (TheBigBugICC)
Ciao Grothus,
scusa, ma utilizzo il traduttore automatico, non ho capito se devo risponderti via email oppure sul forum. Comunque risponderò ad entrambi i messaggi.
Confermo: L’Istituto Comprensivo di Castelvetro (ICC) è un insieme di scuole che vanno dalla scuola d’infanzia (3-5 anni) alla scuola elementare (6-10 anni) e scuola secondaria di primo grado (11-13 anni).
Ti ringrazio per l’attenzione mostrata alle nostre difficoltà e ti auguro buona giornata (anche se qui sono le ore 9 di sera).
Thanks for the reply @ThebigbugICC. I just finished adding you to the database so you are all set to deploy the app if you have not already done so. Just make sure that you do not skip any steps as you deploy the app. Skipping steps will cause errors later on.
Ciao, sono l’animatore digitale di una scuola di Como e ho il tuo stesso problema. Come hai risolto?
Hi @ChiaraFilippini, thanks for the post and sorry to hear that you are having difficulty using the SketchUp for Schools app. If you are getting a login loop, the usual causes of that are blocked popups or blocked cookies.
Can you check those settings and make sure that they are enabled for the site?
Hi, thank you so much for your help, I’ve solved the problem! I thought I had to modify something from the administration account but the problem is about the browser and I have to do it on every school computer. Thank you so much.
Glad to hear you are up and running again ChiaraFilippini! If you need any additional assistance please feel free to start a new thread anytime! I am always happy to help however I can.
its so ANNOYING[quote=“ThebigbugICC, post:1, topic:326835, full:true”]
[/quote]
