About the LayOut category
If you’re having a problem in LayOut, or wish to report a bug, do so in this category.
have you seen my post “Layout not opening any files” ? Every time I try to open LO 2019 it crashes, what can I do?
I am having an issue with PDF Export since upgrading to 2023 2 days ago, is there a fix? it will eventually export after about an hour.
This topic is not supposed to get replies, it’s only here to tell you what this part of the forum is for.
To answer your question though, 2023.1 has a new feature where you can set a document to convert raster viewports into vector or hybrid when you print or export. Go to File/Document Setup, and look at the new option for Rendering. If you want your PDFs to export as raster, uncheck the box for Output Override. That will then export quickly.
