It would be a create if there is a line tool that works like the tape measure tool, so you can click on the bottom of a wall and type in dimensions and get a horizontal-vertical line where ever you wanted without having to clicking on each side with the current line tool to create a line, it will speed up the process and make the program more efficient!
Can you show an example of what you are trying to accomplish?
What version of SketchUp are you actually using? There is no SketchUp 2017 Go version.
Until this function will be added.
What tool is that? One of Curic’s? (Can’t see the name on my tiny little phone screen)
In one sentence you seem to use a ‘Dimension’ tool and a ‘Line’ tool instead of the ‘Tape Measure’ tool, just to rapidly see lengths of edges?
The ‘Tape Measure’ tool shows information about geometry (edges, vertices, face areas, groups, components etc.) when hovering over the geometry.
Yes, it’s Curic Dio 2 > ChalkLine
thanks @mihai.s that’s exactly what I meant, but I wish it would be a SketchUp native tool that does that because extensions make my program slow and crash.
Thanks I didn’t realize that’s my profile is SketchUp go instead of pro.
I had a few extensions don’t remember each name here are a few fredo 6 joint push pull
when I deleted them my program stopped misbehaving
Sounds to me like you are talking about the line tool.
1 select the line tool.
2. click on a point.
3. Infer the direction of your choice.
4. Type the dimension.
Hit enter, You are done!
His description may not have been great, but open up the tape measure tool and you will see what he meant. The tape measure creates a construction line offset parallel to the first line you click on.
The offset tool itself requires you to select two lines, so the offset tool isn’t a great choice. I always draw a perpendicular line to create my offset distance first, then draw my parallel line, then delete the perpendicular line; this turns a one-step process from other apps into a 3-step process in Sketchup (although most applications do it via a reference point inside the line tool).
