5D+ Plus - Flexible Documentation For Architects
Hello, is there anyone got the same issue. Is it surely 100% cause by 5D+ Plus? Because I cannot procedure this issue also searching in my code, and still have not receive other report yet.
I haven’t tested this issue, but when classifier is open it sometimes interferes with Sketchup trays like styles options. I have to close classifier and then the tray works fine. It’s not always and it might be related with changing from sketchup to another app.
I haven’t worked with breadcrumbs and overlay classification yet. However, when nothing is selected, clicking ‘‘make components’’ on the Building Element doesn’t change anything, and clicking ‘‘make group’’ causes the entire model to disappear.
I thought you said it happened to you also?
I don’t think you are supposed to right click on overlay buttons… Buttons are meant only for left click - to apply predefined tag on currently selected objects.
Agree, I saw that it was an option and I couldn’t resist the temptation by right-clicking on them :wink: I suppose this could be removed.
I just wanted to draw attention to this issue.
Although you might find the frequent updates from 5D+ PLUS a bit overwhelming, we simply can’t resist sharing this announcement with you! :joy:
5D+ PLUS Version 1.8.2 (Release date 2025.02.06)
New and Changes
  • Added feature that allows user to select other Tags Visibility preset for current view/scene.
  • Scene names in 2D Drawing panel now automatically changes when user rename the scene.
  • Added an option for user to choose creating nested groups follow IFC hiearchy or not when using Auto IFC feature.
  • Fix bugs not create custom scene when clicking the plus button.
Hey man, I think there maybe something related to the SketchUp version, what is the version you are using?
I’m using the latest version.
And could you try to remove 5D+ Plus in a couple days to see if the reason comes from 5D+ Plus or not?
I have continued using 5D plus and not had the problem in days. It’s because I keep classification turned off. I can turn classification back on and force the bug to happen again.
@Cyentruk Not sure if this is the right plugin to ask this question but since you base a lot of your workflow around tags: What’s the easiest way to hide the tag of an object that I have just selected. I just realized that I need to do that rather often. I click on an object that is “in the way” look in the element inspector what tag it is on, then go to the tags pallet, search for that tag name and hide it. There likely is a better way. there likely also is a plugin JUST FOR THAT but since I have everything 5D+ already installed I wanted to ask here first for best practice before stacking plugins on top of plugins.
  1. I’d use 5d+Selector with predefined tags or Curic Birdcage
  2. Or,++Layer extension by Fbu_Layer_Plus
The latest verision 1.8.2 has a new feature called Tags Visibility. It works like tag states manager. If you understand your tags system and setup via scenes settings, then you can use Tags Visibiilty for easy swiching between tag states.
In other case, I use 5D+ Auto Tag to switch on/off tags, because my model is organized by tags so I know what tag is assigning to the objects without must check object first.
I find it a little confusing that “tags visibility” is related to tag scenes rather than the 5D selector. Wouldn’t it be better if it were simplified and the 5D selector were introduced there instead of scene tags?
Selector is a tool to select objects by tags or materials, completly not related with the visibility of tags.
  • I use 5D Selector often. Tag visibility seems unusable to me. Gather more opinions and see what people say :wink:
  • Is it possible to add this option?
  • The offset between Custom Bounds and the Sec.Mark=0, but I have a 3000mm gap between them. How can I fix this distance, because my model doesn’t fit on the drawing and I have to manually move all these marks with Curic Stretch?
Thank youuuu :heart:
That means selector might be used as tag visibility only if you have birdcage, right?
While tags visibility setups, might allow you to create your own tag sets…?
I hope you don’t mind if I respond :wink:
The 5d Selector lets you select the group for reports and isolate them from the rest of the model.
With Birdcage, you have more control (for example, you can add additional tags to the isolated one)
As @Cyentruk mentioned Tags Visibility is for selecting which tags are turned OFF in a particular scene. This setting is set and saved for every scene independantly. It’s not meant for you to dynamicaly change tags visibility although you can if you want to…
5D+ Selector is a dynamic tool for slecting objects. It’s meant to simplify selecting objects and is not tied to any particular scene. For example you can select all doors in a model and add annotation to those objects with 5D+ annotation tool.
