2D export only shows shadows!
Hi,
I am using sketup make 2015 and when I export 2D it gives me only the shadow and the whole model is hidden. I tried changing everything still same problem. I tried the same file on another PC it worked fine. Please help.
I’ve never seen that exact thing before but try the following and see what happens.
In SketchUp, go to Window>Preferences>OpenGL.
Untick the box for Use hardware acceleration.
Click OK.
Try exporting again.
If that fails, perhaps you could share the SKP file here.
That worked great!!! Thanks a Lot…
Good. It might be worth checking to see if there are any driver updates for your graphics processor.
Another way to achieve the situation in your image would be to paint the model with a totally transparent PNG texture and use a style with edges turned off.
Anssi
