2025 - 3D Connexion Mouse Not Working
OK Guys, yes I know this comes up every year…well at least for me it does.
So after I think I got the But Splat thing solved? When I re-installed 2025 Version 25.0.0.571 64 Bit? No matter how many times I install the driver 3DxWare64_10-9_b671 from 3D Connexion? It will not load into the 2025 SU.
I open the extension manager and the extension is not there. See below:
It is alive and well in my 2024 SU as shown below:
Not panicking as this happens every yearly upgrade but it would be nice if somehow we could find a .rbz file to just load in?
Oh well any suggestions lease let me know what worked for you and I will run through the process…
I did not have any issues. I just installed the latest driver and restarted it, and it worked. The latest driver version is 10.9.3.671.
You might try Cleanup Windows installation from the 3D Connexion website.
I think you need a system reboot for 3DC to add the driver in SU2025
Did that…several times but thank you for the suggestion…
I can do that…thank you!
Yea it worked fine the first tie I installed 2025 and yes I downloaded the latest driver before I installed 2025…downloaded the driver twice yesterday just to make sure so I know it’s the latest…
OK trying that now…
OK so no matter what I tried the software will not be recognized by SU 2025…sigh…
Think I might just uninstall the 3D software and re-install and see what happens…
Again…if at first you don’t…blah blah blah…
OK guys just a update…for those that might have this problem as well…I had to uninstall the 3D Connexion software…go in and manually delete any folders with 3D on them and then re-install the software…and “Viola”…everything is working with my 3D mouse…whew…
Thank you for all the help!..
I had the same issue.
Thanks so much for posting this fix!
This solution worked for me as well.
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
