2024 SketchUp Tape Tool Problem
Hello Community!
I’m having problems with the tape measure tool in 2024 Sketchup Pro.
I’ve attached a video for a better preview of the issue.
Basically, I’m unable to see the tape line either by moving and setting the distance or by typing in the value of the distance.
I’m using SketchUp Version 24.0.554 on MacBook Pro 15.0 (24A335)
It looks to me like you have visibility of Guides turned off?
I checked both places and Guides were checked on.
I even tried unchecking, but as soon as I used the tape measure tool again, it was checked on again.
That is weird then. I’m on Ventura (13.7) not Sonoma. New Graphics Engine vs. Classic? Not sure what else.
Can you upload your model in your next post for someone to get a deeper look at it?
Here is a model where I’m having the same tape measure guide invisibility on SketchUp Pro 2024.
In SketchUp Pro 2023 I dont have issues with the tape measure guide lines. It’s only an issue in 2024 version.
SKETCHUP FORUM - TAPE MEASURE ISSUE -24_1024.skp (449.5 KB)
I have no problem adding guides in your model.
I suggest that, in Model Info → Units, you uncheck Enable length snapping.
I have never used this feature since I can enter exact measurements when drawing or editing.
Also, your model is very small if it is a real building. You should be modelling using real world dimensions.
You can easily scale your model. Simply use the Tape Measure tool to measure a known length. You shall see the length of this edge in the dimension window. Immediately type the real dimension and press the Enter key to validate the input. When asked if you want to resize the model, click yes.
If you really want the building to be that small, for 3D printing, for example, make it a component then make a copy and scale down that copy.
You can use the real sized building for modelling. The smaller copy will automatically be corrected as you go.
I have the length snapping at. 1/16".
This is a scaled down model for 3D printing. But even if I start modeling from scratch, I still dont have the tape measure guides.
Thanks for looking into it!
Having length snapping enabled can cause issues. Most of the knowledgeable people in the forum have it disabled.
Probably a graphics issue which other Mac users have reported. Do a search of the forum on the topic.
Currently it’s a long way from being ready for the slicer. Lots of non-solid objects that need fixing.
How large are you expecting it to be when printed? When I model for 3D printing I do it such that meters in the model equal millimeters in the resulting printed object. This helps to avoid issues with things like missing faces that prevent objects from being identified as solid.
Still, no success by disabling the length snapping.
Disabling Length Snapping is not related to the guides showing or not.
As others have reported, guides show just fine for me in your model.
Guides
Go into SketchUp’s Settings under the SketchUp menu. Choose the Classic Graphics Engine under Graphics. Restart SketchUp and see if you get different behavior.
That’s my graphics info… I doubt it is the problem, as I dont have the same problem on 2023 version of SketchUp Pro.
The 3D printing model is still in the works. My max print size is about 13" square. I may have to redesign the model, so that I have multiple parts, in case I want it to be a large sculpture. It’s not a commercial job for me----I’m just thinking of making this for my father as he was one of two engineers of that building.
I expect it IS the problem. The graphics engine was changed for SketchUp 2024. It is not the same as in SketchUp 2023 and your old Intel GPU may not fully support the new graphics engine used in SketchUp 2024.
You could at least try my suggestion. It won’t hurt anything and it might work.
Amazingly that was the problem! I found the solution here.
Solution is:
SketchUp > Settings > Graphics > Use classic graphics engine
Which is what I told you to try but you told me that wasn’t it.
Thank you! I may have missed the part when you suggested the settings. My apologies!
Kinda off topic but that’s a building I would instantly recognize from miles away. :heart: :armenia:
Nostalgia hits pure, especially when you’re far away from homeland. Great job mate!
