Thank you - I’m aware of that. This zoom behavior was introduced with the latest version SketchUpin combination with macOS Sierra.
I am having the same issue with Layout being greyed out when in SketchUp Pro. Tried the Activity Monitor but I am unclear as to how to tell where Sketch Up is launching from or how to fix it. Running Sierra 10.12 and Sketch Up 16.1.2418. What are my options?
just installed the new OS sierra. but after that, my sketchup pro 8 is not opening.
can any one help,
regards,
Simon
[quote=“architectsimon, post:73, topic:26490, full:true”]…OS sierra vs. sketchup pro 8…
can any one help,[/quote]
I have the send to layout issue, but I also have an issue with no scolling features being available or shown in layout itself; Both vertically and horizontally. Anyone else have this issue?
Here’s an update on the issue where “Send To LayOut” is greyed out, and sometimes the dock icons can turn into question marks.
We’ve talked to Apple - this issue is a side effect of some security improvements that they made in Sierra. For most users, you’ll just have to wait until we can get another bug fix out the door. If you’re an advanced user, start reading up on “app translocation” and the quarantine xattr “com.apple.quarantine”. In theory, deleting the quarantine flag will stop the translocation system from running SketchUp from a temporary location.
Hi Marc,
How long will it take to get the bug fix done? “app translocation” ad “quarantine matter” sound like it would take me way too long to research and understand a fix. But in the meantime I have big projects in process that require Layout today. Are you really telling us that there is no current way to fix the issue at all and that we simply can’t use Layout?
-Derek
@derekb, you could recursively remove all of the quarantine flags from SU v16 using Terminal.app using the following code…
sudo find /Applications/SketchUp\ 2016 -xattrname com.apple.quarantine -exec xattr -r -d com.apple.quarantine {} \;
sudo [superuser do] will ask for an admin password…
find will search the SU folder for any ’ -xattrname com.apple.quarantine’ and pass them to ‘xattr’ for it to remove the flags found…
I’m not running Sierra but this code works on El Capitan and older…
john
Hi John,
Thanks for spelling it our for me, much appreciated. It worked and Layout is accessible again!
-Derek
LayOut still runs if you run it by hand, right? Instead of using “Send To LayOut”, save your SketchUp file, run LayOut, and then do a File->Insert to import the SketchUp model.
-m
Here’s another workaround that the knowledge team is testing.
- Rename your existing “/Applications/SketchUp 2016” folder to something else.
- Create a new “/Applications/SketchUp 2016” folder
- If you don’t already have a copy of the 2016 SketchUp installer, download one.
- Double-click on the installer.
- In the window that opens, double-click on the “SketchUp 2016” folder in the installer.
- Copy the three applications to your desktop (SketchUp, LayOut, Style Builder)
- Run each of them once from the desktop.
- Copy the app bundles to the folder you created in step 2
This series of steps will trigger Sierra to clear the quarantine flag.
I have almost the same issue. Crashing while labelling with leader. It sometimes hangs and sometimes give a bug splat. No problem if labelled outside model, no problem with dimension and label without leader. I am using Sketchup Pro 15 on Sierra
When using the “Send to layout” link in SU (under the file menu) Layout will hang indefinitely once I have chosen a template.
If I open layout then insert a drawing it seems fine.
Having installed the updated version of SU, it now seems the ‘Send to Layout’ option is permanently faded and can’t be used?
Hanging when you’re trying to open a template is a sign that you may not be running the newest version of LayOut. We released a mac-only maintenance version to fix text-related issues on Sierra, and that was one of the symptoms.
If “Send to LayOut” is greyed out, try the install steps I give about four posts up. Or you can run the following command in the terminal: “xattr -d com.apple.quarantine LayOut.app” (for all of the app bundles - not just LayOut).
Hi Mark, I’m on Sierra (why oh why do I jump on these new releases before I read this forum) Luckily, I’ve found no bugs yet. I’m woking on SU Pro. and am working on several projects. Fingers crossed. I do have an issue that I reported on with Section Cut Face and Super Section that baffles me. Please check that topic out that I just wrote if you think you might be able to help.
thanks
Tom Simmons
I am waiting to upgrade to Sierra and to update Sketchup until all problems are resolved. Please advise at the proper time and in what order that should be done. (Sierra-SketchUp or SketchUp-Sierra)
Speaking from experience, not as a voice of Trimble (I do not work for them), you can be reasonably comfortable that any update of SketchUp that claims to be OK for Sierra will also run correctly on prior versions of OS X. So it would be safe to update SketchUp first. As to timing, Trimble never announces release dates in advance. So just keep an eye out for any updates to 2016 and for the release of 2017, which if the past few years are typical will be in a few weeks.
Hi Fred-
Unless you have a compelling reason to upgrade, I’d give it another month. My personal philosophy for version upgrades is that it’s always safest to wait for the first maintenance release before upgrading. Especially for a professional user, I’d recommend waiting to upgrade until you have a lull in business (Thanksgiving or Christmas break, perhaps) on the rare chance that you have upgrade issues and can’t use your machine for a few days.
When you do upgrade to Sierra, I would recommend upgrading SketchUp first, then Sierra. That way you’ll be able to identify any issues with SketchUp without it getting mixed up with any potential Sierra issues.
-m
Thank you Marc! This solved a heart-stopping problem for me and I can deliver my project to my client on time!
thank you
