I have an extension that cycles through all the existing tags, regex maps the tag name to a camera orientation, zooms extents, makes a scene, then publishes those scenes to Layout on 8.5"x11" paper.
This seems to be a very simple solution, except that my window has to be roughly 8.5"x11" or the zoom level is incorrect in LO. Would anyone care to share a more robust solution than zoom extents?
I have a solution for Ortho that involves knowing the size of what’s captured and setting the scale. But I haven’t been able to figure it out for perspective.
Thanks and Regards
Just learned how to paste code. This gives different results in LO depending on the aspect ratio of the SU window. Any ideas on how to get consistent results when viewing in perspective?
# simple_scenes.rb
module SimpleScenes
def self.model
Sketchup.active_model
end
def self.scenes
model.pages
end
def self.view
model.active_view
end
def self.add_lo_view bounds, page, scene_num, layer
skp_model = Layout::SketchUpModel.new(model.path, bounds)
skp_model.current_scene = scene_num
page.document.add_entity(skp_model, layer, page)
end
def self.make_scenes
scenes.to_a.each { |s| scenes.erase(s) }
view.zoom_extents
scenes.add 'reset'
#... other scenes
end
def self.send_scenes_to_layout
model.save
dirname = File.dirname model.path
filename = File.basename(model.path, '.skp') + '.layout'
lo_path = File.join(dirname, filename)
paper_width = 11
paper_height = 8.5
lo_file = Layout::Document.new
skp_layer = lo_file.layers.add('Model Views', false)
lo_file.page_info.width = paper_width
lo_file.page_info.height = paper_height
lo_file.page_info.display_resolution = Layout::PageInfo::RESOLUTION_HIGH
border = 0.25
view_bounds = Geom::Bounds2d.new(border, border, paper_width - 2*border, paper_height - 2*border)
add_lo_view(view_bounds, lo_file.pages.first, 1, skp_layer)
#... add more views
lo_file.save(lo_path)
Sketchup.send_to_layout(lo_path)
end
make_scenes
end
Here is one method to change size of window
Thanks to @ eneroth3
I installed Eneroth Viewport Resizer and changed make_scenes to
hWnd = Ene_ViewprtResizer::GetActiveWindow.call
current_size = Ene_ViewprtResizer.get_size(hWnd)
Ene_ViewprtResizer.resize(true, [1100, 850])
view.zoom_extents
scenes.add 'reset'
#... other scenes
if true
Ene_ViewprtResizer::ShowWindow.call hWnd, 3 #SW_MAXIMIZE
else
Ene_ViewprtResizer.resize(true, current_size)
end
end
The code I’m using has the same debilitating issue. I’d be glad if someone had a solution.
In my case I’m exporting a 2D image so I can control the aspect ratio, but the zoom is wrong depending on the viewport ratio.
Sketchup.active_model.active_view.write_image(f2.path, 2600, 1600, false, 0.0)
Neil_Burkholder:
How about ?
def write_view(path, width, height, antialias = true, compression = 1.0)
model = Sketchup.active_model
view = model.active_view
camera_old = view.camera
aspect_old = camera_old.aspect_ratio
aspect = width.to_f / height.to_f
view.camera.aspect_ratio= aspect
view.zoom_extents
view.write_image(path, width, height, antialias, compression)
UI.start_timer(0.5,false) {
view.camera= camera_old
view.camera.aspect_ratio= aspect_old
end
write_view(f2.path, 2600, 1600, false, 0.0)
