Would someone be so kind as to test if this code works for you?
It works for me but apparently not for other computers. I don’t know if it is due to the language of the computer.
The code reads an xml file generated by a scheduling software (Microsoft Project) and creates two hashes in the model with the task data.
This is the xml file Test Project3.xml.zip (9.4 KB)
module Rtches
module Functions
extend self
def self.loadXmlFileFromProject()
require 'rexml/document'
include REXML
@model = Sketchup.active_model
@model.start_operation("dates import", true)
xmlfilename = UI.openpanel("Open XML File", "c:/", "XML Files|*.xml||")
return unless xmlfilename
xmlfile = File.new(xmlfilename)
begin
xmldoc = Document.new(xmlfile)
@fechasdict = @model.attribute_dictionary('Sketchup4D',true)
XPath.each(xmldoc, "//Task") { |e|
@fechasdict.set_attribute 'Tareas',e.elements["GUID"].text,[e.elements["Name"].text,
e.elements["Start"].text,e.elements["Finish"].text,e.elements["WBS"].text,
e.elements["ID"].text,e.elements["Summary"].text]
valuetoadd = e.elements["WBS"].text + " " + e.elements["Name"].text
@fechasdict.set_attribute 'Tareas2',valuetoadd,e.elements["GUID"].text
test1 = @fechasdict.attribute_dictionary('Tareas').count
test2 = @fechasdict.attribute_dictionary('Tareas').count
if test1==0 || test2 ==0
UI.messagebox('no tasks found, please check your xml file')
else
UI.messagebox("#{test1.to_s}"+' tasks imported')
end
rescue
# mistake message
UI.messagebox('the file could not be imported, please check the file content.')
end
@model.commit_operation
end
end
end
Rtches::Functions::loadXmlFileFromProject()
The file I uploaded was the one which it’s supposed to fail with the code I posted. If the problem is the encoding it must fail in all computers, mustn’t it?
Well the default encoding for SketchUp should be UTF-8, but an extension could change this. (We hope not though.)
I haven’t yet tried the code. I do see that you use File.new instead of File.open and a block which would automatically close the file after use. Any particular reason why?
Ran the code on a new empty model. … it said “13 tasks created”.
After getting the newer Attribute Inspector properly installed I do see the 13 tasks in the 2 subdictionaries.
Win10 SketchUp 22.0
I did a little cleanup …
(1) The bailout clause should always go before you start an operation, otherwise there will be a operation left open.
(2) Wrapped the file object in the block form of File.open …
(3) … added an encoding: 'UTF-8:UTF-8' argument to tell the method that the file is UTF-8 encoded and the internal encoding is the same.
(4) Added an ensure clause to close the file object in case of an error.
EDIT:
(5) Added a statement in the rescue clause to send the exception to the console.
module Rtches
module Functions
extend self
require 'rexml/document' unless defined?(::REXML)
include ::REXML
File.open(xmlfilename, encoding: 'UTF-8:UTF-8') do |xmlfile|
test2 = @fechasdict.attribute_dictionary('Tareas2').count
else
end
rescue => error
puts error.inspect
# mistake message
ensure
xmlfile.close
end
end
end
end
It does not show any error because it jumps directly to the rescue section.
The only thing that may be happening is that the model they are working on shows that it is read-only.
Could the error be due to the fact that it is read-only and cannot execute part of the code?
Thank you very much for your suggestions, they help me to improve.
EDITED the above snippet …
[ I didn’t notice that it was suppressing all errors before. ]
Could be (if on Mac) as adding attribute dictionaries an attribute values modifies the model.
On Windows, I can open a read-only model to modify and SaveAs into a new file with a different name. So we should not get an error until a Save is attempted. (Manually this happens by showing a messagebox with a “Try again with a different filename” message.)
You might be able to detect that the open file is read only,… File.writable?(@model.path)
… and if not, force as SaveCopyAs.
