I’m a Woodworker and I’m please to present you a plugin that I wrote to easily generate Woodworking Cutlist from Sketchup Models.
This plugin is developed around a French woodworkers community platform : L’Air du Bois (https://www.lairdubois.fr) and as the platform it is Open Source and you can access to the source code here :
I gave it a quick trial. It looks pretty good. There are a few things I find odd but it could be due to what I’m used to.
I’d rather not see ‘x’ preceding the quantity of components.
Although the exported file is given the CSV extension, it appears to be Tab separated.
It would be nice if the quantity was the first column.
I’m not clear on the reason for raw and final dimension columns since the dimensions are the same. The raw dimensions only seem to appear in the exported file, too.
After exporting and clicking on Open, I get the following message although the CSV file is saved into the directory. It also makes the rest of the screen go black.
It is mainly here to avoid to confuse it with other kind of value. But maybe you’re right
Arf, do you think it’s better to have a TSV extension or use comma instead of tabs. But commas could be present in part names or materials.
Yes you point a problem. This is because parts of you model has no materiel or their material type are not defined. You need to define the type Solid Wood or Sheet Good in the Materials tab. And then the raw value have sens because is correspond of what you cut.
Outch, a bug. I think it’s because the directory of your file has spaces.
I think it would be best to make it clear it is a TSV file and not CSV. You’re right about there being commas in part and material names which would screw up the table if it is a CSV file.
Oh.
Can you get around that? It wouldn’t be unusual for directory names to have spaces.
I have tried it and it works fine.
I often use it !
The reference path must be a full path to an existing file - otherwise it won’t open anything.
Do you get any error messages ?
To show how it works _outside_ of your code, use this in the Ruby Console...
path = "C:/xxxx/xxxxxx/xxx"
where path is a string identifying an existing file.
Check that it exists with:
File.exist?(path)
Returns true if it exists.
Then use:
UI.openURL("file:///#{path}")
The file will open.
It works on any supported OS.
Are you using it exactly as I showed ?
With surrounding “”, the word file and the : then three/ and the #{} around the path reference ??
There should be no space between the openURL and opening ( - and don’t forget to close the )
The argument is a URL. The file: part says you want to access a file on the local system. The first two // are the base of any URL, e.g. http://. The third / says the base of the path is the root of the filesystem. On Windows, this is equivalent to C:\.
Wrong! You don’t need the third slash if your path is relative. I assume you mean you will include C:, but that is the wrong way to format a URL, use / instead (unless you meant you will include the leading / in the value of path).
Using file:/// works on MAC and PC.
You could reduce the number of / on a PC and it’d still work, but why bother - the /// version is cross-platform safe anyway…
