All of the indented areas in my pergola are supposed to be cutouts. What is the quickest way to cut out these areas? The pergola started off as a 2D drawing in sketchup. I filled it in with the pencil tool and then used the push/pull tool to give it dimension.
On my phone now so I can’t actually look at your model, but usually the way is to pushpull one rectangle through to the other side (taking care to stop there so you create a hole). Then with pushpull still active, double-click other rectangles to extrude them the same distance.
