Hello everyone
I have a question, why the webdialog window is much faster when viewing than htmldialog? thank you
you need to provide some example code, as it isn’t normally the case…
CEF using html5 in a HtmlDialog will outperform IE and Safari [sometimes] that are used in WebDialogs…
unless you have a lot of redundant code…
john
thank you john
already I tested with empty pages without codes, to see the reaction time, so I noticed that the webdialog is faster than htmldialog
the initial start of the first HtmlDialog may have some overhead as CEF has to set up it’s links to SU…
it is feasible that a blank page could take longer than one with content…
test with at least :set_html('hello') for both types…
john
My plugin has 630 parameters 730 language translations and 116 drop down lists.
All of it has to be populated.
Here are some times in seconds on a 5 year old PC on Windows 10 and SU 2018
Open IE 4 times
2.117058
2.057668
2.05745
2.038558
Open Chrome 4 times
1.293675
0.678351
0.647008
0.639863
thank you jhon
hi gjernan ; how do you open in chrome?
html_version = RUBY_VERSION[0..2].to_f >= 2.2 && @cfgs.new_browser
if (html_version)
@dlg = UI::HtmlDialog.new({
:dialog_title => title,
:preferences_key => dialog_name,
:scrollable => true,
:resizable => true,
:style => UI::HtmlDialog::STYLE_DIALOG
else
@dlg = UI::WebDialog.new(title, false, dialog_name)
end
set_form_size(@dlg, width, height, left, top) if (! html_version)
