I have SU pro and seperate vray Preminum. After update SU 2022 to 2023 my V-ray is gone in SU. And it is not under extensions.
If I try to load V-ray standalone outside SU I will just see a “dos prompt” excecuting window.
How do I get V-ray into SU 2023 so I can see the toolbar again ?
Thanks.
I would guess that re-installing V-Ray would prompt it to see SketchUp 2023 and install the required extensions. If you feel adventurous you can try copying V-Ray extension and its folder from the SketchUp 2022 extensions folder to the 2023 one but the first option is the one to be recommended.
Thanks - Yes that might be the solution.
Solved - you were right thanks
