I’ve been trying to create an 80s Old-Timey Tron look on some 3D text I’ve made. I drew some text, traced it in illustrator, saved it as a .dwg file, imported it into Sketchup, and used the Soap Bubble extension to create my geometry.
I applied the Vray Edges texture to the geometry but for some reason it is also applied to the hidden geometry even though the hidden geometry check-box is not checked. At first I thought it was something wrong with the texture, but I also applied it to a simple cube and it works on that. The only thing I can think of now is that perhaps Soap Bubble Geometry does not lend itself well to the Vray Edges texture.
Essentially all I want is the Sketchup style to be the texture. I don’t want the triangles I just want squares like in the screen shot below. Any ideas on my dilemma? Thank you.
