V Jig (2).skp (141.2 KB)
This is a Router Table Sled for a 3/8" dovetail bit. It will have stop blocks and the box clamped to it. The skp has the scenes and each component is tagged. Hope I got rid of all
the loose geometry from cutting the notch using intersect faces.
V Jig (3).skp (136.9 KB)
I just deleted the loose geometry and added (3) skp.
You can use Solid Inspector 2 to check if all your components are solid. Clean up any stray edges, internal faces or surface border issues. Then hide them or cut to clipboard, and see if any loose geometry is left in the model.
Unhide or paste in place all the solid components to get a cleaned up model.
Thanks, I used the Inspector that comes with “Go”. I now routinely turn off the visibility on tags to check for loose geometry, and it’s working fine.
That sounds like a good alternative.
