I am using Sketchup Pro 2022 and V-Ray 5.20.06. My rendering is images getting improper now. It says following errors in log:
Could not load IES file “D:/sketchup/Materials/IES Profiles/16.ies”
Can also see highlights in render logs as shown in Screen shot.
can anybody help me pls
Is ‘D:/’ your drive or did you download the model from online? If ‘D:/’ is your drive, did the folder or .ies light get renamed or moved? You can re-path to the .ies file in the Lights Section of the Asset Editor:
Also, are you meaning to view your render in Magenta? If not, you can switch back to RGB by selecting the green dot in the Frame Buffer.
