V-Ray Interactive Frame Buffer over exposed, how to fix this?
Hi,
My V-Ray interactive frame buffer is over exposed.
I played around with some settings but cannot seem to find the cause…
Any ideas??
Thanks!
In V-Ray Asset Editor > Settings > Revert to Default Render Settings (bottom-right)
Also, check the other lights you introduced in the scene (Rectangle Light, etc …)
Thank you!!
In addition to what @mihai.s said, sometimes just adding an exposure correction layer and manually adjusting will fix it. You can do that in the frame buffer by clicking the ‘+’ sign in the corrections flyout menu. You can and should also look at bringing your ‘Highlight Burn’ down as well.
