Unexpected File Format - Recover please
塔楼su组件.zip (7.8 MB)
hi there, my files cant be open, it come out this unexpected file format. so anyone can recover my file ?
I couldn’t recover anything in the scene, but this has the materials and components recovered.
塔楼su组件_recovered.skp (9.0 MB)
Okay, it looks like it’s impossible to save :sob: :sob: :sob:, but thank you for your efforts!
The file is a lot smaller, so there may have been a lot of loose geometry in the scene, or perhaps grouped. Any components should be in the recovered file.
There seems to be nothing in the recovered file :sob:
There is nothing in the scene, but look in the Components and Materials trays.
Successfully retrieved most of the models! ! ! Thank you so so so so much,!!!this is what makes me most happy this month! :star_struck: :star_struck: :star_struck:
hello my skp file also has the same issue it says unexpected file format, is it possible to recover it??
No one has a chance to tell you how likely it is to recover your file until you share that particular file.
Sorry here is the skp file link thank you! https://drive.google.com/file/d/1POYepTDack6BBBFcJHNM5WHqcTEiO9S7/view?usp=sharing
I see the file is created in Sketchup 23.0.397. Since there are an updates for that main version, as well as newer versions… I assuming you are using a cr_acked Sketchup software. If it is the case please obtain a legal version and you will be able to open your file also.
I was able to open it in SU2026 which automatically repaired it.
Can you upload the repaired file? are u able to save in lower version so i can try to open again? or i need to update my sketchup to latest version?
Are you using c r a c k e d version of Sketchup 2023?
(By the way, since Sketchup 2021, Sketchup can open newer versions of Sketchup files. And since 2024 - officially - you can’t save to an older version.)
no but i will download the latest version if it needs to open it
can you upload the repaired file?
Well, the file can be opened also a in a legal version of the latest SU2023 (Build 23.1.340. )
The fact you still using Build 23.0.397 and you don’t want to update, for me means it was not obtained from a legal source.
Go to your Sketchup, open Menu>>Help>>Welcome to Sketchup.., and navigate to Licensing tab (lover left corner).
Make a screenshot, that you have
a)Subscription Plan: Subscription status: Active
or
b)Classic License: Licensed to…
and share that screenshots here.
