I have been using Sketchup for a while now for designing small construction projects.
This is the first time I have tried to use Layout to produce a set of documents.
I can insert a file, toggle scenes and styles, but I have no control over the viewport, which has a red outline and blue triangle tags. If I select any of these the port disappears never to be seen again.
I thought this was a system error to begin with and cleared out all old versions of sketchup and associated files, updated everything and cleaned and restarted the whole show. No change.
I am hoping it is a user error on my part… Have I overlooked something very basic in the insertion process that would cause this to happen?
Thanks for the response. The file I was working on is too large to post
so I have inserted an element of the original into an identical LO
template (attached). (This is still too large so here is a dropbox link)
Hope that works
Meanwhile I will be studying my layers more closely…
I have… but I have mixed feelings about the slightly desperate “business” of making software redundant. I also have a feeling that that might not be my problem. I will see if there is a trial version of SU2016 to test the theory.
You can download the SU2016 Pro as a 30 day trial and see if you have a different result. It’s odd that you have this thing happening in LO2014. Does it happen if you reopen the saved version of the LO file?
I have tried every permutation of file insertion I can think of and it is always the same problem in SU2014.
I have just tried the file in Su2016 and everything works fine.
Looks as if the accountants have come up with another clever idea…
I will have to bite the bullet as I have a job to do.
That same file and others opened fine in SU2016… no corruption there.
I have lost count of how many variations of file saving /loading/sending/dragging/inserting I have tried.
I have lost the best part of a day playing around with this and as self employee I only get paid for actually producing the goods.
It would be interesting to know why… but meanwhile I am not going to lose any more time.
