I’m trying to move a circle. This is on a plane that isn’t exactly matching an axis (FWIW).
I’m trying to drag it, but it moves in the exact opposite direction I move my mouse. I’ve been able to move things before with the mouse and it worked correctly then. What’s going on?
If it’s what I think it is, it’s a bug I reported over a decade ago and it’s still not fixed…that is an object moving in the opposite direction to the mouse when zoomed right in at certain angles. I encounter it all the time; usually when trying to move an object in empty space.
One possible way of accurately moving the circle to where you need it would be to actually draw a couple of lines on this off-axis plane that intersect at the target point…then pick up the circle by its centre and snap it there. If you don’t want those cross-hairs to mess up the outline of the circle, then either group it before you move it or draw a tiny line stub to the target point (one that will fit inside the circle without intersecting it) and delete the longer lines.
happens to me when i am detailing timber joinery, zoomed in close, lots going on… if you are moving it via numerical value, just add a negative sign ‘-’ to the number you want to move it before you type it. it should move in the correct direction then.
I ended up just typing in my coordinates. It was a little frustrating but
I got it to place where I wanted it. Yes, and it was the same situation
Mike say, zoomed in with lots of holes/dimensions.
