Truebend smooth object
How can I smooth an object after using or before using Truebend? The last pic is in SuperSlicer and the surface is not great.
01
02
Truebend defaults to 24 segments but you can increase or decrease that.
Pull the bend then type 48s or 96s and hit enter twice to finish. You can also type the deg first if you want to be specific.
For example, start to pull, type 180 enter 48s enter enter and you have a 180deg bend with 48 segments.
360s would give you one segment per degree, probably overkill but see what works for you. The more segments the larger the file and the more potential lag etc
Thanks Box, it is so easy when you know how. :+1: :+1:
