I’ve lost the face on this model and need help getting it back. Tried drawing lines across it to troubleshoot but no luck. File attached.Adirondack Chair Base.skp (202.3 KB)
Open the component for editing and trace an edge segment with the Line tool.
Thanks DaveR for your help.
FIxed that problem but now I have a hole that I can’t complete with push/pull. I can’t seem to get rid of the back face of the hole.Adirondack Chair Base.skp (279.7 KB)
Try erasing the wall of the hole and the circle on the back. Then trace and edge segment on the circle on the front face and push it through again. See if you can get it create a through hole them. I did that and it worked here.
You have two circles on the back that don’t line up.
worked like a charm. Thanks again.
