is there a possibility to select and delete any coincident groups or components which are a duplicate/copy on the same place?
I have a huge facade and I used the copy/array command with identical objects, afterwards while rendering I saw that there are several copies overlapping each other. If I could select all duplicates which have the same coordinates, I could delete them, instead of figuring out where they are.
Vectorworks for example has such a function, its called. “Purge coincident double objects”
The question was to leave one instance in place per location.
Manually you could window-select around a component while having ‘Entity Info’ open.
Once you see (say) 11 instances, but seemingly only one selected, [Shift]click once on the selection again to reduce the number of selected instances to 10. Only then hit [Delete].
A plugin would be better to speed up the process for an entire model. Could be out there already. Search the ‘Extention Warehouse’ or the ‘Plugin Store’ at SketchUcation forum.
