It may for light models (as some users said in the other thread.)
However, have been issues with integrated graphics in the past. The screen could smear when using tools (usually linked to a fast feedback setting.) In some instances the whole modeling window will have herringbone or dithered interference pattern all over it.
The Intel spec page …
https://ark.intel.com/content/www/us/en/ark/products/208652/intel-core-i3-1115g4-processor-6m-cache-up-to-4-10-ghz.html
… also only states only “Intel® UHD Graphics for 11th Gen Intel® Processors”.
But the launch date was 3rd quarter of 2020 so it is only 6 months old. Basically it’s the latest generation of the i3 family, but not the latest “set” of releases. (There’s another set, just released this past quarter, that has 8MB cache, 4 cores but only 3.90GHz at boost.)
Looking at the lists of higher grade iCore processor families, they all (that have integrated graphics) state a certain “model” number, whereas the i3 do not. So we can assume the generic UHD in the i3 processors is the bottom tier, bare bone graphics offering.
I specifically just set SU2017 to use my integrated UHD Graphics 630 and SketchUp started. The OpenGL Details window does display a warning because CheckUp is now integrated within SketchUp and runs during the application load. The warning …
SketchUp found the following:
- SketchUp has detected you are using a “Intel(R) UHD Graphics 630” graphics card when your system is capable of using an AMD or NVIDIA graphics card. SketchUp will likely perform better if you change your system to use the AMD or NVIDIA card.
Updating your graphics card drivers might fix the problem.
See this Help Center article for more information.
This warning would not appear if the system had no dedicated graphics beyond the integrated.
Anyway the model display looks okay. And I get no smearing with tools operations such as moving things or stretching objects. No smearing during rectangle tool.
HOWEVER when I switched back to the browser on another display (to type the above) after a minute or so, SketchUp 2017 just crashed with no BugSplat! window. Ie, the application just closed.
I checked for a Windows Error Report and it did not catch the crash either.
I switched SU2017 back to the Nvidia GTX 1060, did the same quick tests, and it is still running happily.
So if Tiger Direct (or whomever) has an acceptable return policy you can try that Lenovo machine and if it does not work return it.
But because of many issues Trimble SketchUp division does not recommend integrated graphics.
And why we here in the forums also encourage getting a machine with dedicated graphics.
I myself am also concerned with the small 8GB memory where the integrated graphics has to steal from system RAM. But again your models are lightweight. This memory stealing is supposed to be adaptive … only taking what it needs when it needs to.
