Thickness to complex surfaces
Here is a model i made wich is for mounting pumps in it. I would like to give the whole structure 20mm of thickness, is there an easy way to do it? I have tried with joint push and pull and it does some of it byt it is a lot of manual work. maybe there is a easier way? I have uploade the model here.
Namnlös.skp (500.2 KB)
I would divide the element into two mirrored components, select the ‘‘vertical wall’’ edges, and then create faces using the Soap Skin extension. I assume the mesh will be clean, allowing you to create thickness easily
Joint push pull thickener? Select all the surfaces and then do it?
Before you do that though I would get your faces oriented properly.
Ha! i am an idiot…thats why it did not work properly for me, i had the surfaces in different ways. Thanks!
If you want an approximation that is not to far from a perfect 20 mm thickness and all done with basic tools, click in sequence on the scenes tabs of this SU file for ideas.
Namnlös - JL - 2025-02-24.skp (1.9 MB)
Thanks!!
