Hi. When you use the line tool on objects, it’s supposed to create lines that are integrated in the object, and those lines are supposed to be a part of the surface. However, I find that very often when I try to draw lines on an object, they create a new surface on top of the object, instead of as part of the object surface. How do I make this distinction? How do I tell Sketchup that it has to create those lines as part of the object I’m working on? This is of fundamental importance, as I’m shaping the object with the help of the lines I’m drawing, pushing and pulling the surfaces into their proper intended places.
This used to be no problem. I drew an object, drew lines on the object, and manipulated the object however I wanted. But now, more and more consistently, Sketchup treats me drawing lines on an object as separate surfaces appearing on top of the object, but not as part of it.
Yes, it’s a component. Is that a problem? It doesn’t always react like this, just sometimes. Sometimes I just have to try a few times to get it right, but right now it treats all of my trials the way I don’t want.
I can see that it’s no longer a component when I open this separately saved object. But that’s easily fixed by rightclicking and making it a component. However, this is as far as my knowledge goes.
I just drew the two smaller rectangles. Note that there’s a difference in thickness of the edges. However, this thickness is not consistently present, even though I’m having problems. Sometimes the trouble is still there with a thinlined rectangle, but the thicklined ones seem to be the least cooperative.
The thicklined one doesn’t even want to have anything to do with the surrounding surface at all. It just happens to be proximate, and does not care about what the rest of the lines and surfaces are doing.
The thinlined one, on the other hand, is connected to the rest of the surface, as you can see. It creates a rectangular incision when pushed into the surface, and the surface is pulled out. But I both drew them the exact same way, using the same mouse tool, and one right after the other.
So I really don’t understand why they should behave so completely differently, because I made them the exact same way, just on slightly different places on the same object.
I guess the thick lines mean that these are the outer edges of a shape, but I have no clue why it chooses to make a new shape on top of the other, instead of being lines integrated in the first object.
So I’m very confused and handicapped by this. Thing is, I don’t even think this makes sense. How often when you draw lines a surface do you want them to become a new object on top of the other one? My guess i very rarely, and so it would make sense to me that Sketchup would only allow this event if you were holding some key in simultaneously, to really mark this as a special event.
Edit: Put several comments into one, for tidiness.
