char* c_file_path = RSTRING_PTR(file_path);
char* c_thumbnail_dir = RSTRING_PTR(thumbnail_path);
SUModelRef model = SU_INVALID;
SUResult res = SUModelCreateFromFile(&model, c_file_path);
if (res != SU_ERROR_NONE) {
rb_raise(rb_eRuntimeError, "Failed to create a new model");
SUStylesRef styles;
SUModelGetStyles(model, &styles);
size_t style_count = 0;
SUStylesGetNumStyles(styles, &style_count);
SUStyleRef* style_array = (SUStyleRef*)malloc(sizeof(SUStyleRef) * style_count);
if (style_array == NULL) {
return EXIT_FAILURE;
size_t count = 0;
SUStylesGetStyles(styles, style_count+1, style_array, &count);
for (size_t i = 0; i < count; ++i) {
SUImageRepRef thumbnail = SU_INVALID;
SUImageRepCreate(&thumbnail);
SUResult thumbnail_result = SUStyleGetThumbnail(style_array[i], &thumbnail);
if (thumbnail_result == SU_ERROR_NONE) {
SUImageRepConvertTo32BitsPerPixel(thumbnail);
char filename[256];
snprintf(filename, sizeof(filename), "thumbnail_%04zu.jpg", i);
char full_path[512];
snprintf(full_path, sizeof(full_path), "%s\\%s", c_thumbnail_dir, filename);
thumbnail_result = SUImageRepSaveToFile(thumbnail, full_path);
if (thumbnail_result != SU_ERROR_NONE) {
rb_raise(rb_eRuntimeError, "Failed to save thumbnail to file: %s", full_path);
if (i >1)
SUStylesRemoveStyle(styles, &style_array[i]);
printf("Style %zu has a valid thumbnail.\n", i);
else {
printf("Style %zu does not have a valid thumbnail.\n", i);
SUImageRepRelease(&thumbnail);
if (i > 1)
memset(style_array, 0, sizeof(SUStyleRef) * style_count);
free(style_array);
SUModelRelease(&model);
SUTerminate();
return Qtrue;
Please post code correctly in the forum:
It is also best if the description of the problem in in the post, not in the topic title. (For quoting purposes, etc.)
What version of the SDK are you testing on?
I see there are Ruby C API calls in your code. This would indicate that this is a Ruby C extension running inside SketchUp’s process. If so, then this:
SUTerminate();
… should not be called.
using SDK_WIN_x64_2025-0-634
Yes, deleting it did not change the result
I did not think it would.
I also did not see any report similar in the official API Issue tracker:
Would we expect the size to be around 4K ?
