Anyone know whether its possible to increase the line spacing within text blocks in Layout. I need to include a specification on a drawing and need to get better legibility with increased line spacing.
I can’t see anything within the show fonts box. I realise layout uses the default OSX font interface and can’t believe that there is no way to control this important element of typography given that the mac was ALL about typography from the start.
I created this
text in the text edit.app
I set the line spacing
to 0.8
then I pasted it into a text block in
Layout. The text block retains the line
spacing even though I have replaced all of the
original text from the outside app.
It is a kind of left handed work around. But
it works
The sample layout sheet shows the result.
I wish there were better text editing features in Layout.
William, that is great!
I had actually seen the effect but didn’t realise the connotations of copying from Pages or Notes etc.
Good man, thanks very much indeed.
I’ve now set up a Pages document with the margins set to my standard text block size on my layout template so I can set out the text and retain the same wraps, paragraph breaks etc.
Line height control is an existing feature in LayOut. On a Mac, select Show Ruler from the TEXT pulldown menu. Then select your text and the Spacing dropdown appears in the upper right portion of the ruler. Selecting “Other …” offers several spacing options including before and after paragraph spacing.
Is this what you were referring to? I’m mostly impressed you were able to comment on a post from nine years ago
