Tally of exterior walls
Hi.. i am looking for a quick way to tally all the exterior measurements for walls
What measurements are you referring to? The area of the faces? the length of the perimeter?
Are you still using SketchUp for iPad?
Using i pad
I can hi lite the perimeter with select arrow and assume there must be some way to add up all the walls - as per pic attached
Highlight all of the edges and look at Entity Info. It will tell you the total length of the selected edges.
No info in entity info section once I have li lighted the perimeter..
That’s because you have also select the face. As I said, select just the edges.
length
Perfect.. thanks Dave
