SU 2025 - Customize Toolbar?
I’ve just moved up to SU 2025. In SU 2022, when selecting “Customize Toolbar”, an entire palette/menu of all buttons appears where you can drag selected items up to your own top line toolbar. In 2025, when selecting “Customize Toolbar”, nothing appears? Where do I find all the choices/options to populate my toolbar?
Thanks!
In Sketchup 2025 the best way to select tool bars is to choose the view pull down menu and select tool bars then use the check boxes for visibility. That is the same as in previous versions. The “Customize Toolbar” is used in Layout. That is still the same in 2025 however 2026 has issues and behaves different. If you are talking about Layout 2026 the customize option is still there when you right click on a toolbar, but you have to copy the Icons to populate a New Custom Toolbar.
This problem happens if you have certain extensions installed, one of which is Selection Toys. We have a work around to the problem, that hopefully will appear in the next update. For now you have to uninstall Selection Toys if you need to customize the toolbar.
I have found that just disabling Selection Toys via the Extension Manager then restarting SketchUp will let the customization happen.
