I’m having a weird issue on the iPad version of SketchUp. When I draw a square along the blue axis, it ends up looking like a diamond instead of a square. But if I reference a line (instead of a guideline), it goes back to looking like a normal square.
Does anyone know why this happens or how to fix it?
Hi Mike I managed to figure it out I was wasn’t able to locate the axis tool but I just used the search tool and found it that way, then managed to reset the axis.
There is no ‘axis tool’ - on desktop you can position where you need, then reset it as needed. I assume it is similar on iPad with different mechanics.
Edit: after 20 years of SKP I learned there is an ‘axis tool’.
