Split in 2
I have an object that I need to split into two so i can edit them later, separately, then put back together. I have the free version.
Any ideas?
Thanks.
Slice.stl (4.8 MB)
Open the object for editing and draw a rectangle through the geometry where you want to trim split it. Then close the object and make a copy of it. Then edit them one at a time, use Intersect Faces to create an intersection where the rectangle passes through and then erase the unwanted bits leaving just the one half.
It’s great that you shared the file but please download and share the .skp file with us, not the .stl file.
Please correct your forum profile. There is no free version of 2025 Desktop.
