Hi Experts,
I am using those C APIs to write out sketch up files. since my output data is tessellated mesh, I googled and found soften edge can help “connect” facets, so I called following codes when create a LoopInputRef item.
for(int i = 0; i < 3; i ++ )
SULoopInputEdgeSetSoft(loopRef, i, true);
//SULoopInputEdgeSetSmooth(loopRef, i, true);
After this I found a cylinder model all faces(top, bottom and cylinderical face) were connnect and single click will select all faces. What I want is can act as native sketchup application’s selection behavior for a cylinder body(3 faces selectable).
And even worse this model can’t be re-soft by the sketchup application when select all faces and righ click->soft edge…
2.skp (21.7 KB)
Could you help take a look?
