Sketchup scene cannot sync into lumion when 2 point perspect is set
hi, im using skp pro 2022 with lumion sync extenssion and lumion pro 9.5
after setup two point perspective scene in the skp, and launch lumion sync, the scence will not show the lumion directly. But it work without two point persepctive set in skp.
how could i fix it. thanks very much
Hello,
I guess you gave yourself an answer. Lumion fails to transpose a 2 points perspective.
disactivate it, and use lumion’s 2 points perspective effect instead. It’s a shame it’s not applied automatically when facing this during sync, Lumion’s at fault there. (perphaps it works better in most recent updates ? 9.5 is starting to be quite old)
thanks Paul. much appreciate your reply.
Yes, have to set up scence and apply two point perspective in lumion manually.
that is a pity that no other update verison in my hand. is this also happen on higher version lumion?
All the best
