Sketchup rendering vray cloudy
Does anyone knows how to remove the cloudy thing on my cabinet
What rendering program are you using?
vray sketchup
So this is a Vray question. You really should add that information when you make the post in the first place.
The Vray experts will be along but the first thing I’d look at is the material properties for the material on the cabinet.
what about the materials
The mottled lighting isn’t just on the cabinet. It’s covering the entire room. Not sure what’s causing it, though. It could be a modifier on your lighting, or refraction from the glass chandelier. I’m not a Vray expert, though.
Hello to everyone!
Please help me with an answer to this problem described by @killerkss. All my renders are cloudly and I can’t find a solution. I tried rendering with and without dome light, I replaced the HDRI map, I rendered only with sunlight but also with sphere light and rectangle light and some of them turn out even worse. I use Sketchup 2024 and Vray 7. I have denoiser activated, I have modified the values and it still doesn’t adjust. I have reduced the values of the materials used for reflection color and glossines, and still no.
Please help me!
Thank you!
These are called ‘blotches’ and are typically signs you have a problem with your Illumination settings. What are you using for GI? Irradiance map + Light cache? If so try switching to Brute Force+Light Cache. See if that makes a difference.
