How to remove the white splotches for my render?
Here is my render picture , i am still a student , learning about vray. Can anyone teach me how to remove the white dots / splotches? Thanks
Did you make any changes to the rendering settings? More precisely at GI?
Reset to default and render again.
Check for reversed faces. As @mihai.s says, start with Default settings. Turn on Denoiser. Is your white material unrealistically light (255,255,255)? Is the beam a closed shape?
Use brute force instead of irradiance map?
This could possibly also fix the light leaks at the ceiling.
I solved the problem, at first I’m using GPU and I change back to CPU, set my primary rays to irradiance map then its fine. Thanks for the effort :pray:
Using brute force cause me the problem so I change to irradiance map
