SketchUp Pro 2019 failed to install
I receive an error while installing SketchUp Pro 2019. The detail message is as follows:
Component Visual C++ “14” Runtime Libraries (x64) has failed to install with the following error message:
"Fatal error during installation. "
The following components failed to install:
- Visual C++ “14” Runtime Libraries (x64)
See the setup log file located at ‘C:\Users\david\AppData\Local\Temp\VSD1EAA.tmp\install.log’ for more information.
Here is the setup log file:
The following properties have been set:
Property: [AdminUser] = true {boolean}
Property: [InstallMode] = HomeSite {string}
Property: [ProcessorArchitecture] = AMD64 {string}
Property: [VersionNT] = 6.2.0 {version}
Running checks for package ‘Microsoft Windows’, phase BuildList
Reading value ‘CurrentVersion’ of registry key ‘HKLM\Software\Microsoft\Windows NT\CurrentVersion’
Read string value ‘6.3’
Setting value ‘6.3 {string}’ for property ‘OsCurrentVersion’
Reading value ‘CurrentBuildNumber’ of registry key ‘HKLM\Software\Microsoft\Windows NT\CurrentVersion’
Read string value ‘17134’
Setting value ‘17134 {string}’ for property ‘OsCurrentBuildNumber’
The following properties have been set for package ‘Microsoft Windows’:
Property: [OsCurrentBuildNumber] = 17134 {string}
Property: [OsCurrentVersion] = 6.3 {string}
Running checks for command ‘SketchUpPrerequisites64\MinimumWindowsVersion’
Result of running operator ‘VersionGreaterThanOrEqualTo’ on property ‘VersionNT’ and value ‘6.1’: true
Result of checks for command ‘SketchUpPrerequisites64\MinimumWindowsVersion’ is ‘Bypass’
Running checks for command ‘SketchUpPrerequisites64\64BitArchitecture’
Result of running operator ‘ValueEqualTo’ on property ‘ProcessorArchitecture’ and value ‘AMD64’: true
Result of checks for command ‘SketchUpPrerequisites64\64BitArchitecture’ is ‘Bypass’
‘Microsoft Windows’ RunCheck result: No Install Needed
Running checks for package ‘Universal CRT (Hotfix KB2999226)’, phase BuildList
Looking up path for special folder ‘SystemFolder’
Running check with folder ‘C:\Windows\System32.’ and file ‘ucrtbase.dll’
Attempting to find file ‘C:\Windows\System32.\ucrtbase.dll’
File version is ‘6.2.17134.319’
Setting value ‘6.2.17134.319 {version}’ for property ‘UCRT’
The following properties have been set for package ‘Universal CRT (Hotfix KB2999226)’:
Property: [UCRT] = 6.2.17134.319 {version}
Running checks for command ‘SketchUpPrerequisites\InstallPrerequisites.exe’
Result of running operator ‘VersionGreaterThanOrEqualTo’ on property ‘UCRT’ and value ‘0.1’: true
Result of checks for command ‘SketchUpPrerequisites\InstallPrerequisites.exe’ is ‘Bypass’
‘Universal CRT (Hotfix KB2999226)’ RunCheck result: No Install Needed
Running checks for package ‘Visual C++ “14” Runtime Libraries (x64)’, phase BuildList
Running MsiProductCheck with ProductCode ‘{F106B700-BFF8-3065-B305-14D36AD40539}’
MsiQueryProductState returned ‘-1’
Setting value ‘-1 {int}’ for property ‘VCRedistInstalled’
The following properties have been set for package ‘Visual C++ “14” Runtime Libraries (x64)’:
Property: [VCRedistInstalled] = -1 {int}
Running checks for command ‘vcredist_x64\vcredist_x64.exe’
Result of running operator ‘ValueGreaterThanEqualTo’ on property ‘VCRedistInstalled’ and value ‘3’: false
Result of running operator ‘ValueEqualTo’ on property ‘AdminUser’ and value ‘false’: false
Result of running operator ‘ValueNotEqualTo’ on property ‘ProcessorArchitecture’ and value ‘AMD64’: false
Result of running operator ‘VersionLessThan’ on property ‘VersionNT’ and value ‘6.00’: false
Result of checks for command ‘vcredist_x64\vcredist_x64.exe’ is ‘Install’
‘Visual C++ “14” Runtime Libraries (x64)’ RunCheck result: Install Needed
Running checks for package ‘Microsoft .NET Framework 4.5.2 (x86 and x64)’, phase BuildList
Reading value ‘Release’ of registry key ‘HKLM\Software\Microsoft\NET Framework Setup\NDP\v4\Full’
Read integer value 461808
Setting value ‘461808 {int}’ for property ‘DotNet45Full_Release’
Reading value ‘v4’ of registry key ‘HKLM\SOFTWARE\Microsoft\NET Framework Setup\OS Integration’
Read integer value 1
Setting value ‘1 {int}’ for property ‘DotNet45Full_OSIntegrated’
The following properties have been set for package ‘Microsoft .NET Framework 4.5.2 (x86 and x64)’:
Property: [DotNet45Full_OSIntegrated] = 1 {int}
Property: [DotNet45Full_Release] = 461808 {int}
Running checks for command ‘DotNetFX452\NDP452-KB2901907-x86-x64-AllOS-ENU.exe’
Result of running operator ‘ValueEqualTo’ on property ‘InstallMode’ and value ‘HomeSite’: true
Result of checks for command ‘DotNetFX452\NDP452-KB2901907-x86-x64-AllOS-ENU.exe’ is ‘Bypass’
Running checks for command ‘DotNetFX452\NDP452-KB2901954-Web.exe’
Result of running operator ‘ValueNotEqualTo’ on property ‘InstallMode’ and value ‘HomeSite’: false
Result of running operator ‘ValueGreaterThanEqualTo’ on property ‘DotNet45Full_Release’ and value ‘379893’: true
Result of checks for command ‘DotNetFX452\NDP452-KB2901954-Web.exe’ is ‘Bypass’
‘Microsoft .NET Framework 4.5.2 (x86 and x64)’ RunCheck result: No Install Needed
Installation of components ‘Visual C++ “14” Runtime Libraries (x64)’ was accepted.
Copying files to temporary directory "C:\Users\david\AppData\Local\Temp\VSD1EAA.tmp"
Copying from ‘C:\Users\david\Downloads\sketchup_install\vcredist_x64\vcredist_x64.exe’ to ‘C:\Users\david\AppData\Local\Temp\VSD1EAA.tmp\vcredist_x64\vcredist_x64.exe’
Verifying file integrity of C:\Users\david\AppData\Local\Temp\VSD1EAA.tmp\vcredist_x64\vcredist_x64.exe
WinVerifyTrust returned 0
File trusted
Running checks for package ‘Visual C++ “14” Runtime Libraries (x64)’, phase BeforePackage
File trusted
Installing using command ‘C:\Users\david\AppData\Local\Temp\VSD1EAA.tmp\vcredist_x64\vcredist_x64.exe’ and parameters ’ /quiet /q:a /norestart ’
Process exited with code 1603
Status of package ‘Visual C++ “14” Runtime Libraries (x64)’ after install is ‘InstallFailed’
On attempting to install the Microsoft Visual C++ 2017 Redistributable (x64) - 14.15.26706 separately, I also received a Setup Failed message. Here is the log file:
[1B90:1BBC][2019-03-13T08:26:39]i001: Burn v3.7.3813.0, Windows v10.0 (Build 17134: Service Pack 0), path: C:\Users\david\Downloads\SketchUpPro-2019-0-685-20289-en\vcredist_x64\vcredist_x64.exe, cmdline: ‘’
[1B90:1BBC][2019-03-13T08:26:39]i000: Setting string variable ‘WixBundleLog’ to value ‘C:\Users\david\AppData\Local\Temp\dd_vcredist_amd64_20190313082639.log’
[1B90:1BBC][2019-03-13T08:26:39]i000: Setting string variable ‘WixBundleOriginalSource’ to value ‘C:\Users\david\Downloads\SketchUpPro-2019-0-685-20289-en\vcredist_x64\vcredist_x64.exe’
[1B90:1BBC][2019-03-13T08:26:39]i000: Setting string variable ‘WixBundleOriginalSourceFolder’ to value 'C:\Users\david\Downloads\SketchUpPro-2019-0-685-20289-en\vcredist_x64'
[1B90:1BBC][2019-03-13T08:26:39]i000: Setting string variable ‘WixBundleName’ to value ‘Microsoft Visual C++ 2017 Redistributable (x64) - 14.15.26706’
[1B90:1BBC][2019-03-13T08:26:39]i100: Detect begin, 10 packages
[1B90:1BBC][2019-03-13T08:26:39]i000: Setting version variable ‘windows_uCRT_DetectKey’ to value ‘10.0.17134.319’
[1B90:1BBC][2019-03-13T08:26:39]i000: Setting numeric variable ‘windows_uCRT_DetectKeyExists’ to value 1
[1B90:1BBC][2019-03-13T08:26:39]i102: Detected related bundle: {d992c12e-cab2-426f-bde3-fb8c53950b0d}, type: Upgrade, scope: PerMachine, version: 14.0.24215.1, operation: MajorUpgrade
[1B90:1BBC][2019-03-13T08:26:39]i052: Condition ‘(VersionNT = v6.3 AND NOT VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)’ evaluates to false.
[1B90:1BBC][2019-03-13T08:26:39]i052: Condition ‘(VersionNT = v6.3 AND VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)’ evaluates to false.
[1B90:1BBC][2019-03-13T08:26:39]i052: Condition ‘(VersionNT = v6.2 AND NOT VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)’ evaluates to false.
[1B90:1BBC][2019-03-13T08:26:39]i052: Condition ‘(VersionNT = v6.2 AND VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)’ evaluates to false.
[1B90:1BBC][2019-03-13T08:26:39]i052: Condition ‘(VersionNT = v6.1 AND NOT VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)’ evaluates to false.
[1B90:1BBC][2019-03-13T08:26:39]i052: Condition ‘(VersionNT = v6.1 AND VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)’ evaluates to false.
[1B90:1BBC][2019-03-13T08:26:39]i052: Condition ‘(VersionNT = v6.0 AND NOT VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)’ evaluates to false.
[1B90:1BBC][2019-03-13T08:26:39]i052: Condition ‘(VersionNT = v6.0 AND VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)’ evaluates to false.
[1B90:1BBC][2019-03-13T08:26:39]i103: Detected related package: {50A2BC33-C9CD-3BF1-A8FF-53C10A0B183C}, scope: PerMachine, version: 14.0.24215.0, language: 0 operation: MajorUpgrade
[1B90:1BBC][2019-03-13T08:26:39]i103: Detected related package: {EF1EC6A9-17DE-3DA9-B040-686A1E8A8B04}, scope: PerMachine, version: 14.0.24215.0, language: 0 operation: MajorUpgrade
[1B90:1BBC][2019-03-13T08:26:39]i101: Detected package: Windows81_x86, state: Absent, cached: None
[1B90:1BBC][2019-03-13T08:26:39]i101: Detected package: Windows81_x64, state: Absent, cached: None
[1B90:1BBC][2019-03-13T08:26:39]i101: Detected package: Windows8_x86, state: Absent, cached: None
[1B90:1BBC][2019-03-13T08:26:39]i101: Detected package: Windows8_x64, state: Absent, cached: None
[1B90:1BBC][2019-03-13T08:26:39]i101: Detected package: Windows7_MSU_x86, state: Absent, cached: None
[1B90:1BBC][2019-03-13T08:26:39]i101: Detected package: Windows7_MSU_x64, state: Absent, cached: None
[1B90:1BBC][2019-03-13T08:26:39]i101: Detected package: WindowsVista_MSU_x86, state: Absent, cached: None
[1B90:1BBC][2019-03-13T08:26:39]i101: Detected package: WindowsVista_MSU_x64, state: Absent, cached: None
[1B90:1BBC][2019-03-13T08:26:39]i101: Detected package: vcRuntimeMinimum_x64, state: Absent, cached: Complete
[1B90:1BBC][2019-03-13T08:26:39]i101: Detected package: vcRuntimeAdditional_x64, state: Absent, cached: Complete
[1B90:1BBC][2019-03-13T08:26:39]i052: Condition ‘VersionNT64 >= v6.0 OR (VersionNT64 = v5.2 AND ServicePackLevel >= 1)’ evaluates to true.
[1B90:1BBC][2019-03-13T08:26:39]i199: Detect complete, result: 0x0
[1B90:1BBC][2019-03-13T08:26:48]i200: Plan begin, 10 packages, action: Install
[1B90:1BBC][2019-03-13T08:26:48]i052: Condition ‘VersionNT = v6.3 AND NOT VersionNT64’ evaluates to false.
[1B90:1BBC][2019-03-13T08:26:48]w321: Skipping dependency registration on package with no dependency providers: Windows81_x86
[1B90:1BBC][2019-03-13T08:26:48]i052: Condition ‘VersionNT = v6.3 AND VersionNT64’ evaluates to false.
[1B90:1BBC][2019-03-13T08:26:48]w321: Skipping dependency registration on package with no dependency providers: Windows81_x64
[1B90:1BBC][2019-03-13T08:26:48]i052: Condition ‘VersionNT = v6.2 AND NOT VersionNT64’ evaluates to false.
[1B90:1BBC][2019-03-13T08:26:48]w321: Skipping dependency registration on package with no dependency providers: Windows8_x86
[1B90:1BBC][2019-03-13T08:26:48]i052: Condition ‘VersionNT = v6.2 AND VersionNT64’ evaluates to false.
[1B90:1BBC][2019-03-13T08:26:48]w321: Skipping dependency registration on package with no dependency providers: Windows8_x64
[1B90:1BBC][2019-03-13T08:26:48]i052: Condition ‘VersionNT = v6.1 AND NOT VersionNT64’ evaluates to false.
[1B90:1BBC][2019-03-13T08:26:48]w321: Skipping dependency registration on package with no dependency providers: Windows7_MSU_x86
[1B90:1BBC][2019-03-13T08:26:48]i052: Condition ‘VersionNT = v6.1 AND VersionNT64’ evaluates to false.
[1B90:1BBC][2019-03-13T08:26:48]w321: Skipping dependency registration on package with no dependency providers: Windows7_MSU_x64
[1B90:1BBC][2019-03-13T08:26:48]i052: Condition ‘VersionNT = v6.0 AND NOT VersionNT64’ evaluates to false.
[1B90:1BBC][2019-03-13T08:26:48]w321: Skipping dependency registration on package with no dependency providers: WindowsVista_MSU_x86
[1B90:1BBC][2019-03-13T08:26:48]i052: Condition ‘VersionNT = v6.0 AND VersionNT64’ evaluates to false.
[1B90:1BBC][2019-03-13T08:26:48]w321: Skipping dependency registration on package with no dependency providers: WindowsVista_MSU_x64
[1B90:1BBC][2019-03-13T08:26:48]i052: Condition ‘(VersionNT64)’ evaluates to true.
[1B90:1BBC][2019-03-13T08:26:48]i000: Setting string variable ‘WixBundleRollbackLog_vcRuntimeMinimum_x64’ to value ‘C:\Users\david\AppData\Local\Temp\dd_vcredist_amd64_20190313082639_000_vcRuntimeMinimum_x64_rollback.log’
[1B90:1BBC][2019-03-13T08:26:48]i000: Setting string variable ‘WixBundleLog_vcRuntimeMinimum_x64’ to value ‘C:\Users\david\AppData\Local\Temp\dd_vcredist_amd64_20190313082639_000_vcRuntimeMinimum_x64.log’
[1B90:1BBC][2019-03-13T08:26:48]i000: Setting string variable ‘WixBundleRollbackLog_vcRuntimeAdditional_x64’ to value ‘C:\Users\david\AppData\Local\Temp\dd_vcredist_amd64_20190313082639_001_vcRuntimeAdditional_x64_rollback.log’
[1B90:1BBC][2019-03-13T08:26:48]i000: Setting string variable ‘WixBundleLog_vcRuntimeAdditional_x64’ to value ‘C:\Users\david\AppData\Local\Temp\dd_vcredist_amd64_20190313082639_001_vcRuntimeAdditional_x64.log’
[1B90:1BBC][2019-03-13T08:26:48]i201: Planned package: Windows81_x86, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1B90:1BBC][2019-03-13T08:26:48]i201: Planned package: Windows81_x64, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1B90:1BBC][2019-03-13T08:26:48]i201: Planned package: Windows8_x86, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1B90:1BBC][2019-03-13T08:26:48]i201: Planned package: Windows8_x64, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1B90:1BBC][2019-03-13T08:26:48]i201: Planned package: Windows7_MSU_x86, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1B90:1BBC][2019-03-13T08:26:48]i201: Planned package: Windows7_MSU_x64, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1B90:1BBC][2019-03-13T08:26:48]i201: Planned package: WindowsVista_MSU_x86, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1B90:1BBC][2019-03-13T08:26:48]i201: Planned package: WindowsVista_MSU_x64, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1B90:1BBC][2019-03-13T08:26:48]i201: Planned package: vcRuntimeMinimum_x64, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[1B90:1BBC][2019-03-13T08:26:48]i201: Planned package: vcRuntimeAdditional_x64, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[1B90:1BBC][2019-03-13T08:26:48]i207: Planned related bundle: {d992c12e-cab2-426f-bde3-fb8c53950b0d}, type: Upgrade, default requested: Absent, ba requested: Absent, execute: Uninstall, rollback: Install, dependency: None
[1B90:1BBC][2019-03-13T08:26:48]i299: Plan complete, result: 0x0
[1B90:1BBC][2019-03-13T08:26:48]i300: Apply begin
[1610:43A8][2019-03-13T08:26:50]i360: Creating a system restore point.
[1610:43A8][2019-03-13T08:27:17]i361: Created a system restore point.
[1610:43A8][2019-03-13T08:27:17]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{95ac1cfa-f4fb-4d1b-8912-7f9d5fbb140d}, options: 0x7, disable resume: No
[1610:43A8][2019-03-13T08:27:17]i000: Caching bundle from: ‘C:\Users\david\AppData\Local\Temp{95ac1cfa-f4fb-4d1b-8912-7f9d5fbb140d}.be\VC_redist.x64.exe’ to: ‘C:\ProgramData\Package Cache{95ac1cfa-f4fb-4d1b-8912-7f9d5fbb140d}\VC_redist.x64.exe’
[1610:43A8][2019-03-13T08:27:17]i320: Registering bundle dependency provider: ,amd64,14.0,bundle, version: 14.15.26706.0
[1610:43A8][2019-03-13T08:27:17]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{95ac1cfa-f4fb-4d1b-8912-7f9d5fbb140d}, resume: Active, restart initiated: No, disable resume: No
[1610:2F44][2019-03-13T08:27:17]i304: Verified existing payload: vcRuntimeMinimum_x64 at path: C:\ProgramData\Package Cache{C77195A4-CEB8-38EE-BDD6-C46CB459EF6E}v14.15.26706\packages\vcRuntimeMinimum_amd64\vc_runtimeMinimum_x64.msi.
[1610:2F44][2019-03-13T08:27:17]i304: Verified existing payload: cab5046A8AB272BF37297BB7928664C9503 at path: C:\ProgramData\Package Cache{C77195A4-CEB8-38EE-BDD6-C46CB459EF6E}v14.15.26706\packages\vcRuntimeMinimum_amd64\cab1.cab.
[1610:2F44][2019-03-13T08:27:17]i304: Verified existing payload: vcRuntimeAdditional_x64 at path: C:\ProgramData\Package Cache{F106B700-BFF8-3065-B305-14D36AD40539}v14.15.26706\packages\vcRuntimeAdditional_amd64\vc_runtimeAdditional_x64.msi.
[1610:2F44][2019-03-13T08:27:18]i304: Verified existing payload: cab2C04DDC374BD96EB5C8EB8208F2C7C92 at path: C:\ProgramData\Package Cache{F106B700-BFF8-3065-B305-14D36AD40539}v14.15.26706\packages\vcRuntimeAdditional_amd64\cab1.cab.
[1610:43A8][2019-03-13T08:27:18]i301: Applying execute package: vcRuntimeMinimum_x64, action: Install, path: C:\ProgramData\Package Cache{C77195A4-CEB8-38EE-BDD6-C46CB459EF6E}v14.15.26706\packages\vcRuntimeMinimum_amd64\vc_runtimeMinimum_x64.msi, arguments: ’ MSIFASTINSTALL=“7” NOVSUI=“1”’
[1610:43A8][2019-03-13T08:27:18]e000: Error 0x80070643: Failed to install MSI package.
[1610:43A8][2019-03-13T08:27:18]e000: Error 0x80070643: Failed to execute MSI package.
[1B90:1BBC][2019-03-13T08:27:18]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[1B90:1BBC][2019-03-13T08:27:18]i319: Applied execute package: vcRuntimeMinimum_x64, result: 0x80070643, restart: None
[1B90:1BBC][2019-03-13T08:27:18]e000: Error 0x80070643: Failed to execute MSI package.
[1610:43A8][2019-03-13T08:27:18]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{95ac1cfa-f4fb-4d1b-8912-7f9d5fbb140d}, resume: None, restart: None, disable resume: No
[1610:43A8][2019-03-13T08:27:18]i330: Removed bundle dependency provider: ,amd64,14.0,bundle
*[1610:43A8][2019-03-13T08:27:18]i352: Removing cached bundle: {95ac1cfa-f4fb-4d1b-8912-7f9d5fbb140d}, from path: C:\ProgramData\Package Cache{95ac1cfa-f4fb-4d1b-8912-7f9d5fbb140d}*
[1610:43A8][2019-03-13T08:27:18]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{95ac1cfa-f4fb-4d1b-8912-7f9d5fbb140d}, resume: None, restart initiated: No, disable resume: No
[1B90:1BBC][2019-03-13T08:27:18]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart: No
• download required MS Visual C++ 2015 Update 3 x64
• uninstall MS Visual C++ 2015 x64
• uninstall MS Visual C++ 2017 x64
• restart Windows
• install MS Visual C++ 2015 x64 by right-clicking the setup routine and choosing “Run as Admin”
• doesn’t work? => uninstall the 32-Bit versions of the MS runtime libs too… be aware, might brake other applications requiring them
If you’re having C++ issues it looks like we’ve had some positive developments with the release of our latest version of SketchUp Pro 19.2. Due to some changes with how we handle C++, many of the common installation issues don’t seem to be an issue any longer (knocks on wood). We’ve been reaching out to users with these sorts of issues and finding good results. Please give it a shot if you are still troubled with C++ or installation errors. Download All | SketchUp
I have the same issue. Giving up on Sketchup as a result. The fixes seem difficult and could potentially mess up other programs so not good for me.
With SketchUp Pro 2019, or 2021? I think it is fair to assume that there will not be any further changes to SketchUp Pro 2019, if that is the version you are using. You might try a trial of SketchUp Pro 2021, if you have not done so already.
Sketchup pro 2021 Downloaded today.
Your profile says your operating system is Windows 8 SketchUp 2021 does not support Windows 8.
Sorry Profile is not up to date. This is windows 10.
Thanks for updating.
Find the downloaded installer, right click on it and choose Run as administrator. If it is presented, then choose Repair.
It is not presented in the installer. I tried to repair in the OS and it didn’t work either. I also tried removing entirely but no luck. There is an arcane article about installing this separately but it also said that it may affect other programs. So I surrender!
