Sketchup plugins not installing
Hi, I have version 8 on one computer with many plugins.
I have another computer with version 8, and it will not take the plugins. Even after I install the plugin, it says it’s ready to use, but it is not there.
Also, the plugin “heading” on top is missing.
Thanks,
Rick
What plugin are you referring to? Not all of them are intended to show up in the Plugins menu. The Plugins menu only shows up if you install a plugin or extension that is supposed to show up in that menu.
Thanks for the reply Dave, the first one I wanted to install is the angle_between plugin. But there will be many others.
Are you talking about Angle Between Faces by Daiku?
Read the usage instructions to find out where they will be found.
Actually it’s just a standard angle dimension tool
Which one exactly?
Is it installed correctly?
Instead of installing anything, what happens if you copy this folder from the old machine to the new one, and then open SketchUp 8?
C:\Program Files (x86)\Google\Google SketchUp 8\Plugins
I tried angle between faces, and it works in a way that I hadn’t seen before. It has no menu entries, and no windows or help tips of its own. You right click on any single edge, and in the contextual menu it shows the angle between the two connected faces.
