Sketchup Mac - When I import a floor plan it is low resolution. how to fix?
Hi, when I import a floorplan its fuzzy. How do I get Sketchup (Version 24.0.554 Mac) to display the image at a higher resolution?
Thank you!
what format is your plan ? I suspect pdf ?
pdfs don’t import on PC? and on mac they import using an apple importer that changes them to a jpg.
if you want to import a vector pdf, you’ll have to convert it to dxf / dwg first
Okay thank you! I will try that.
You should also turn on “Use maximum texture size” to see full resolution. Having it off is quite crippling.
