To try the new version of SketchUp Diffusion access the Centercode Project here.
The Scribble Tool allows you to “sketch” over the Preview image and combine this sketch with an optional additional prompt to add elements on the generated image such as entourage, landscape, building elements and more.
To use the Scribble Tool you will need to have an image loaded in the Preview space and then follow the steps below:
- Click on the
button from the top right corner of the Image Preview. - Adjust the diameter of the scribble tool using the slider that appears under the button.
- Sketch anything you like directly on top of the image Preview
- Enter an additional prompt in the prompt space (optional)
- Click any of the Diffusion models (Generate, Preserve Color, Relight)
- Preview any of the generated results by clicking one of the first three thumbnails under the image preview
Settings
While the Scribble Tool is active you will be able to adjust the following parameters:
- Prompt Influence: Controls the level of impact the text prompt will have on the generated image
- Scribble Influence: Controls how much the drawn lines will be respected in the generated image output.
