Good morning everyone,
After updating to Sketchup 2025, I noticed a problem with the dimensions: a black rectangle appears instead of measurement, and when hovering over it with the mouse, it’s not possible to select the exact point. However, after saving the file, the dimensions return to normal. Has this ever happened to you? How did you solve it?
Thanks in advance
Are you using new or old graphics engine?
We very recently fixed an issue where black rectangles would appear over dimensions if you have created scenes. It only affected the older graphics engine, and so the problem was mostly seen in the web version.
Changing to use the new graphics engine should work around the problem. The fix is already in the web version, and should be in the next desktop update.
