Make it what you started! But it must be dc! I’ve been working normally for days!
It turned out that Sketchucation (SketchUcationTools_v3.1.3) plugin makes that problem. With modified su_dynamiccomponents.rb and with another enabled plugins (when Sketchucation is disabled) now Vray works fine! Thanks!
It may be that they are related! Yeah! I do not have “Sketchucation” installed!
Now DC load is delayed by 5 seconds. You’ll notice that the icons appear with a delay. Maybe you can put 4 or 3 or less in that code instead of 5 (that’s seconds). When Vray releases the next update, this problem will be resolved and then delete this part of the code that you added.
Thank you!
You’re welcome! I’m glad I helped! ![]()
Obrigada MarkoL!
A única coisa diferente é que coloquei o código sem espaços… “UI.start_timer(5, false){”
Quando coloquei do mesmo jeito do post (com espaços) deu erro na linha, quando tirei os espaços funcionou perfeitamente! ![]()
Coloquei essa informação extra porque pode ajudar mais alguém!
I too have this same issue. How did you solve it? SU 2018 with latest version of Vray 3.6. Either won’t load or crashes SU. Much appreciated. Chris
