I’m bopping along without a care when “show default tray” is ghosted and is long gone.
I created another tray with the same preferences but would like to know how to get the default tray back.
You can only have the utility windows in one tray at a time. Since you have them all in Tray 1, there’s nothing in the Default tray so no Default tray to show. Remove at least some of the utility windows from Tray 1 so you can add them to the Default tray. If the Default tray won’t appear, fgo to Preferences>Workspace and click on Reset Workspace.
Thank you Dave. I’m making progress. I moved a couple of utilities to Default using Manage Trays. Default now shows up at lower right in tiny box. When I click on it it appears in a large un-sizable window which disappears whenever I click in an unused area.
If I reset workspace will I lose my customized toolbars or anything else?
I will try not to use up more of your time. You have been very helpful.
I obviously have been using the forum like a real newby. I went back a couple years and marked your responses to my questions as SOLUTION.
I’ll try to be on the ball about that from now on.
